He can speak for himself, but I suspect SY has not said any of them either.
No, I haven't. As FR can see if he reads any of the articles I've published or posted, I use whatever technology is best to achieve the engineering goals needed for the application.
I use an SRPP front end on my hybrid valve/MOSFET amplifier.
It gives a very clean sound, I was very pleased with it.
Just to be closer to the absolute truth ,you could replace "clean" with pleasant.
CAUTION:
One of the "problems" of a DIY website is that you get folk repeating "Popular wisdom" with no actual experience, whether to try to be helpful or just to try to appear knowledgable doesn't really make a difference.
This results in some tubes getting an undeserved bad name, the 12AU7 is one of these. 12AU7 are stunning if run up at 8.5 to 10mA idle current. At some stage someone has done a design with a 12AU7 running at 1.5 to 2.5 mA and stated that it sounded bad and that has been repeated by enough folk that it is now accepted as a fact.
The real problem with tubes like the 12AX7 and the 12AU7 is that they are so readily available and relatively cheap that they have been used in more bad designs than any other tubes in the history of audio. Both can stunning when used correctly in the right place.
One other thing I saw in circuits above. The LM317 used as a current source. It actually can make a reasonable CCS when used in the right place. In most instances however its high device capacitance means that you get a CCS whose output impedance (the measure of a CCS "goodness") falls rapidly at higher frequencies. Occassionaly that won't matter, usually it does. I don't recommend using LM317 and similar for CCS duty.
Ian
Thought for the day:
The difference between theory and practice is that in theory there is no difference between theory and practice whereas in practice there is.
Ian
CAUTION:
I fully agree.
Me too , I was thinking the same things while reading this thread , yesterday.I fully agree.
Though I sadly admit that I can be included in the big mindless crowd
CAUTION:
Ian
Perfectly right
Would this be an acceptable 6DJ8 Circuit?
Is there any simple way how to reduce gain of this pre? Without changing tubes.. Probably some resistor from output to input
SY,
I am targeting to use 6N1P, "almost" equivalent of 6922/E88CC, with mu about 35 (different values in datasheets, but well 33-37,5). There wont be any potentiometers, directly connected to source. I was trying different simulations in Tina TI, and once I tried simple resistor, just like for chipamps, to set gain.
- Tubes / Valves
- High-End preamplifier with ECC82!
