Hifonics Brutus BXI1610 Amp Help needed
:cop: I've split out your question as was originally suggested by Perry.
question refers to this post by Perry
If there are no shorted output transistors and no output transistors with broken legs, the most common fault for amps using this driver board is the failure of the two transistors in the yellow rectangle.
