Can someone offer some advice on how to debug Hifonics Brutus BXI1610 car amp that is in protect mode? Is it better to check FETs first, or try and remove driver board? Any tips on common issues with this amp would be appreciated.
here are pictures of the two driver boards
Perry, thanks for your help.
There are no shorted output transistors. The amp goes into protect with nothing connected to inputs or outputs.
What are the part numbers of the two small signal transistors in your picture above in the yellow rectangle?
I pulled Q6 & Q7 off of driver board. Using the diode test on my meter, both transistors appear to be ok. I mean they are not shorted or open, and they have no signs of thermal stress on the package.
Leave the Audio Driverboard out of the amp and try powering the amp up does it still protect or is the green light on ?
With the driver board removed, is it ok to power up the amp without the heatsink clips on the output transistors?
Any time that the transistors are off of the sink, you have to be very careful until you know that there is no fault that will cause the FETs to heat up. Even with no fault, sometimes the FETs (or other components) can heat up and fail. Sometimes it happens quickly and sometimes it takes several minutes for them to begin to overheat.
The other 1D and 2D transistors on the boards sometimes fail but it's not as common.
I've checked transistors in the circuit before and they checked open but after removing them, they appeared to be OK. I'd suggest replacing them. They run very hot. Generally, the board is discolored under those transistors because they operate at such high temperatures.
Does anyone have the part number for Q6/Q7? I see where one person substitutes a MPSA42 in to-92 package for more power handling. Is there a schematic of this circuit anywhere? Are these NPN transistors just used as switches?
Does the discoloration on D5/D6 on driver board mean anything? I guess I can take diodes off and check them.
Next I will install heat sink clips, and remove driver board and see if protect light goes out.
MMBTA42
Virtually all of the transistors in the drive circuit for class D amps are used as switches.
I've never seen any problems with the diodes on that board.
There have been instances where one of the TL072s have failed but that generally caused 'no audio' instead of the amp going into protect.
I removed the driver board and the protect light no longer comes on when I power up the amp. So can I assume this is a fault with driver board? Can someone recommend replacement transistors for Q6 & Q7?
Sorry I missed MMBTA42 transistor part number in Perry's port. I ordered some from digi-key.
Does a schematic exist for the driver board?
I haven't seen a diagram for this board. I'm sure that the manufacturer has one but they are not likely to release it. Many times, not even the authorized distributors are given the driver board diagrams.
- General Interest
- Car Audio
- Hifonics Brutus BXI1610 Amp in Protect mode
