Hifonics Brutus BX 2005d
Ok well Q3 is brand new so gonna go after C3 but I dont have that value of capacitor laying around. I have some for Rockford amps like 10uf 63v guess its gonna be more days of waiting for parts.
Do you know the size of that 47uf 16v capacitor?
Can I use something instead to test?
Shorting the collector and emitter should have prevented the relay from engaging by switching the other two transistors off.
89uf is within tolerance for most electrolytics (which are often ±20%).
Are you sure that the relay didn't click immediately when you powered up the amp?
Re-check to see if you still have 14v on both ends of the diode near the relay.
