Hifonics BE35-2500.1D
This amp uses 12 IRFP064N’S for the power supply fets .
Something doesn’t look right here unless I’m over thinking this .
There is a spot for 4 driver transistors but there only 2 in this amp .
Is there supposed to be 4 or only 2 ?
Replaced the driver transistors (C3228) with BD139 .
Once I load the drive circuit all drive signal disappears .
The center pins go to the Battery plus not the negative terminal .
The 2 spots on the board that are not populated are where the pnp drivers would go .
So I’m wondering if the got hot and desoldered themselves and someone took them from the board
I used BD139 for the C3228’s .
You said you didn’t see any diodes so use bd140 of the center pins go to the ground terminal of the amp .
The center pins do not go to the ground terminal of the amp .
The empty locations still remain empty at this point . The empty locations venter pin goes to ground
So do I leave the empty locations empty or pit 140’s in there ?
Let’s try to make this less confusing for both of us .Q7 and Q7A were populated when I revived the amp .
Q7 and Q7A center pin goes to the fets drain (center leg)
Q8 and Q8A were not populated when I revived the amp there center pins go to the ground terminal of the amp . There connection to the ground terminal was never burnt open .
The only thing I found burnt open was a 0 ohm resistor labeled RGND was burnt open which connects from ground terminal of the amp to the rca shield ground of the rca jacks .
So my question is I should leave the 2 bd139’s in locations Q7,Q7a and populate Q8,Q8A with BD140’s correct ?
Post #2:
The collector of the PNP transistors go to ground. Confirm that the center pad is ground and if so, use a BD140.
^^ Why didn't this clear things up?
The center leg of the NPN drivers do not go to the center leg of the drains. They go to B+. The drains are connected to B+ through the transformer.
