Hifonics BE35-2500.1D
Scope set to 5volts/div 10us
Power supply is working correctly now .
All of the outputs and audio driver board are removed from the amp since they were defective .
If I install the rectifiers the amp starts drawing excessive current .
All of the rectifiers rest fine on diode check
Any ideas on what to check since the amp will draw excessive current when the rectifiers are installed ?
Something still isn’t right with this amp .
I installed the rectifiers and pulled all of the rail caps off the board .
With no rail caps install the amp will power up and idle .
If I put the rail caps in the amp it will draw excessive current . I even took caps from another board to test and same thing the amp will draw excessive current .
Any ideas ?
