Hifonics A3000.1D
Hi all,
I have a hifonics alpha 3000.1D that goes directly into protect upon connection of remote power. Nothing on the board looks bad to the naked eye. All of the FETs measure OK.
This amp uses the TL494 for the power supply. I've checked all the SOT23-3 transistors near it and they all "measure" OK. Of course they could've failed in an open state.
I'll check the voltages going into the 2 opamps of the TL494 tomorrow. Does anyone have a schematic for this guy?
Attached some pictures of the amp.
Copy and paste the following list and fill in the blanks. If there is no blank space after the colon, add one between the colon and the numbers you enter. It makes it much easier to read.
DCV on all terminals of the TL494.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
I'll have to check the supply voltage tomorrow. But there are two components that are burnt right behind the RCA jacks. Seems to be coming directly from the signal trace of the RCA as well, makes sense why signal wasn't getting through. Any idea what part they are?
