Hifonic Hercules 4k
A problem with the power supply drive circuit can sometimes be masked if the power supply is regulated. For those, reducing the 12v supply voltage to force the power supply duty cycle to 50% can help determine where the problem is.
If the problem is in the audio circuit, letting it draw current for a few seconds will make the FETs heat up and help determine where the problem is.
This is what I'm getting
Fist picture is the gate second is the drain, no signal at the source.
power supply is set to 13.6 volts.
when I apply the remote and with a 1 ohm current limiter resistor, the voltage drops to 8.5 volts, and without
the current limiter it draws the 35 amps of my power supply in 2 seconds, and
b+ drop to 9.2 volts.
