Hifisonix Micro Ripple Eater
The ripple eater (any ripple eater) will remove LF mains rectification noise off the supply rails. Under no load, a typical amp will have 200-500mV 100/120 Hz sawtooth ripple and that goes up with load. Ripple eaters effectively shift the ripple noise down in frequency so that the changes on the rails go from 100/120 Hz sawtooth to <1 Hz (ripple eater RC time constant specific). You always loose a volt or two across the RE and under load, the DC output will be at the trough of the ripple voltage plus some further DC drop across the series pass transistor.
It will not fix bad wiring resulting in earth loop or common impedance coupling noise. It will improve the PSRR of a system by 30-40 dB.
Increasing the cap filter bank is another way of doing it, but that is gets expensive if you want to reduce the ripple by 30-40 dB and you then have concomitantly higher charging currents to deal with.
As in all things, there is a balance to be had.
This micro has few components more than the original sx/kx amp ripple eater?? (which i have in the works now)
Should i try to add R1, R2, R9, R10, D5, D6 and C3, C4 to older board, if even possible?
No - I'd just stay with the original board. A good upgrade is to replace the MJE15032/22 pass devices with TO3P devices like the NJW3281/1302 and mount then off board on the amplifier heatsinks which is also what I've done on my kx2-Amp. Quite a few builders have done this - it will allow full power testing of the kx2/sx amp into 2 Ohm loads in class A.
Thanks for this addition to your amplifiers Bonsai. I cannot see the dimensions for the MRE pcb. Can someone please post the overall footprint of the board with transistors projecting as I am designing a new case for mine and haven't ordered the actual boards yet.
Oops! I should have said overall footprint dimensions.
Circuit like this is also known as "Lipple Filter" (Luxman M-03)
I've never seen this. You will lose a volt of two in output voltage swing, but that is normally not a problem if the amplifier is powered off sufficiently high voltage rails. What you can do is place the ripple eater after the power output stage but before the small signal stages - I did this in my e-Amp from 2012 ( http://hifisonix.com/ovation-e-amp/ ). The scope shot below is the waveform across D3. The attenuation of supply rail ripple was about 40 dB at LF and >50 dB at HF - top trace was the cathode and bottom trace the anode.
You will have a hard time convincing me any most others that a CLC filter is a better option for filtering the supply rails in a solid state amp all things considered. For a tube amp with high voltage rails and low current draw they may make sense but not in a solid state amp.
Separately, I am of the opinion, as are the experts that study this stuff, that the world is round and about 7900 miles in diameter.
