😀..LOL
Echoplex delay..
No the reason is I watched one expand and contract on start up of equipment and thought its going to break the fuse element over time.
M. Gregg
Not to forget that you are loosing the advantage of quantum tunnelling with this type of construction.
LMAO,
But will they work better if I put them outside in the winter to cryo treat them.
NB they will sound different for sure, the caps will corrode 😀
I like the ones that have a springy tell tail when they blow, you can put a limit switch and a flashing light on them, 😀
M. Gregg
I've got 10A time lag fuses in my Aleph4 with 1000VA of transformers, 264000uF of caps, and no slow start. Those fuses just love the turn ON moment, never had one fail yet though.
LMAO,
M. Gregg
A 24 hour soak in a cess pit would ensure that the optimum balance of protenoids for unparalleled performance.
I think its already been done. 🙄
The unparalleled performance is beyond compare, you get a free temperature test on your mains tranny.
There is something wrong with this fuse, look turn it around and the mains Tx turns into a room heater..😀
I'll try the 10 A version...
Well the fuse has survived.
M. Gregg
It always amuses me that the most expensive audio upgrades available are those that can be fitted by users with little or no technical ability. Go figure!
That's right! We are all wasting our time with custom designed circuits etc.
I bet there's knobs that will unveil the sound.
Revered in audiophile circles for creating gorgeous sounding no-compromise capacitors which grace some of the world’s best electronic designs, Mundorf capacitors are built using a special conductive material. Ultra-pure silver is impregnated with gold creating a material with gobs of resolution and golden warmth; glorious tonal color with truly outstanding dynamic shading, essentially the best of both gold and silver and absolutely no compromise. Each Supreme fuse uses this special material for its end-caps and conductive filament and pure silver solder connects everything. Inside the ceramic casing, Supreme fuses further distinguish themselves by receiving proprietary resonance and quantum treatments
This claim is made for a mains fuse, ladies and gentlemen. A MAINS FUSE.
I must have missed this in engineering school.
Question
Do you believe that a power cable affects sound quality?
After you answer see where it will lead
dazzz, you've been hosed. Sorry, there's no clearer or nicer way of saying that. Think of it as a relatively inexpensive lesson about the avariciousness and total lack of conscience of high end audio accessories merchants.
Here's the business plan.
1) Come up with something that hasn't been done yet.
2) Get it made in China
3) Come up with a suitable description (Pseudo scientific BS)
4) Set up website
5) Make money for old rope
4) Set up website
$1000 mains leads are also total Snake Oil. Any heavy gauge lead will do the same job.
If you want to pay the supplier £100M for gold wire between the power station and your home, then it might hold some truth - UTTER C**P.
For G*ds sake the return to the power station is earth. The same earth that we grow our vegetables in.
Someone's going to chime in now and say that you ought to plant Golden Wheat in the return path rather that Green Beans.
It's a F*****g J**e.
I've got scammed by him and wasted money on speaker cables. That was 10 years ago. I've been warning internet forum members ever since. A few years later, I figured the words have spread enough to put him out of business. Looks like it went the opposite way. 🙄
If you believe that a power cable affects sound quality even in principle
So by the logic
The small fuse that came after him should also affect
And I do believe that the power cords
Well as their effect on the audio and the video especially they are connected to LCD
I am a photographer in second I notice the effect of electrical cable on the image
So by the logic
Dazz, you have been scammed - clear and simple. You've only got cheap audio equipment that wouldn't know the difference even if it were true.
Yes, when I operate my equipment without a power cord, there's a lot less sound.
Look, you got hosed. It's difficult to admit it, that's OK. But don't expect that experienced technical people will go along with you just because you'd prefer to rationalize it. If you ask a question, people will answer it, but they're not going to play make-believe.
I can't believe that he's paying $60 for a fuse in equipment that costs less than $50 in a flea market.
Denon might be better than Sony but it's certainly no-where near hi-end equipment.
As mentioned above the if the power cable is of sufficient gauge then you will not notice any difference between some standard wire and equivalent gauge "audiophile" stuff.
The only times cables have made any difference is when I went from bell wire speaker cable to some thicker stuff (Cheap and heavy duty) and when I went from the worlds cheapest interconnects to some home made silver ones (which only cost about £20 to make).
The small fuse comes before the decoupling caps in the amp so any potential differences between fuse types is wiped out by the effect of the amps circuitry. The amplifier circuitry also has a built in rejection for power supply noise, fluctuations etc... These design features alone make it virtually impossible for a fuse to have any noticeable affect.
Any perceived sound quality changes are exactly that perceived.
Sy. I've got cryogenic recalsurant cables that generate power from no-where, why can't I hear anything out of my speakers ?
On a cheap system to just talk?
It's not just that I have a dollar Amplifier
If you consider the ARCAM FMJ32 Amplifier
Speakers B & W 804
Inexpensive system then you are sure millionaire
Isn't it nice that they always overstep the mark? If only they restricted themselves to saying vaguely plausible things it would be much harder to laugh at them and their gullible customers. Fortunately the nice thing about fools is that they love to advertise the fact.Inside the ceramic casing, Supreme fuses further distinguish themselves by receiving proprietary resonance and quantum treatments
- hifi tuning fuse -amp overheating ?
