Hi i need help wireing amp and crossver
ok... are the low mutes out on the x-over? are you seeing any signal LED's on the amp flickering? what gain settings do you have on the amp?
you need to be more forthcoming with details like, your source device, and mixer settings...
any chance you can upload pictures of your setup and patch?
and can you either show a pic or list your dip switch settings on the back of the amp?
as you said this stuff is all new so should work...
yes i am have a speakon from the amp to the sub 2 xlr from the mixer tp inputs of crossover then xlr 1 2 outputs to amp inputs rgs colin still not working
yes my grand son will do that for me soon rgs colin
