AP2!
Some into just forum pour words the, them will sort readers the!
Hi AP2,
I noticed a new stereo amp module DPA-2030 at audiopower.it. It looks like MDA-400 with SDA-400 on one board, with slightly less power and otherwise very similar specs. How good is this amp in terms of sound quality? Is it suitable for high quality hifi amp (for home listening)? Thanks.
Hi tcx,
Yes, clean up to full power and absolute absence of noise. very compact and complete amplifier.
...have not yet found the right amplifier..deep bass and voice hot as mospower A-B amplifier?
Hi AP2,
well, I have been quite busy with other things last time and I still have to finish the amp based on the ZapPulse 800XE module. It is not so easy as I have a SMPS which provides +-20V aux voltages and the amp needs +-12V, so I have to finish a small board with voltage regulators. And I also have to modify an aluminium case for the amp.
What I especially appreciate on the DPA-2030 is that it is a complete stereo amp with SMPS on one board. I would just need to connect audio inputs, speaker terminals and power and can start to use it.
BTW, do you know its dimensions? I couldn't find them on the website.
Thanks.
Hi AP2,
thanks for the information.
I somehow can't decide which amps from audiopower.it I should buy, to get the best sonic performance for home stereo hifi listening. I am bit confused by their offer. Would you help me to choose the right one, please?
The DPA-2030 seems to be the easiest to build and is reasonably priced.
I also considered two DXA-400 with one DPS-500.
Before DPA-2030 appeared, I considered MDA-400 + SDA-400.
Also dual DPA-200 comes to my mind.
They differ slightly in technical parameters but I do not know if the differences are important for my intention. Also they all are more than enough powerful for me.
So my question is which of them would you most recommend? Are there any significant differences in their sonic character?
Thank you very much in advance! And sorry for asking for your comments and recommendations several times.
Thank you, AP2. Your information is much appreciated.
Also, I wanted to order DPS-400-S for another project but this smaller SMPS disappeared from audiopower.it website. Is it discontinued? Thanks.
