Hello
Are you planning to have room correction feature too?
It's all on the table 😉
cheers
I've been following this thread and patiently looking forward to availability. Have you given any thought to making a face plate available?
I've been following the thread but have lost track of one thing - is it planned as a board only, or will it be available as a completed unit including case/box etc?
A set of boards with the possibility of a completed unit, however there have been some expression of interest from OEM's willing to build completed units for say European or US markets etc which would also have to pass their respective standards for emission and safety etc.
regards
david
regards
david
I hope the unit will be able to switch 110/240V.
yes switchable on the power supply board inside the unit.
regards
david
Any updates on release date and pricing (at least expected range)?
Updates on my facebook page. Pricing < 1K USD.
cheers
cheers
< 1K USD = 1/2~1/3 of what I was expecting This is gonna be big and popular. Can't wait.
If it has the resolution and DSP overhead claimed, then will be very popular. Frankly, I'm tired of hearing from other manufacturers about why the highest possible resolution isn't necessary when doing digital crossovers.
labjr,
is it really the resolution that is necessary in a digital xo or the length of the FIR size that is more critical to what you may want to do? Perhaps these function are equivalent in nature.
I truly hope you will be able to sell these in tens of thousands.
One thing at the time, but I'd love to see someone come up with two blocks of 4x nCore amps to pair it with this. Unfortunately, nCore only comes is 400W version which is a bit too much for the upper range of frequencies and it would be kind of a waist.
Thank you for all the effort up to now. It seems this will end up as a worth waiting device. I will certainly spread the word.
labjr,
+1
labjr,
All I know is that I can hear the difference between different sample rates. Having to resample down for processing seems destructive.
I'd rather use four identical amps(five needed for Linkwitz LX521.4). This way everything has the same gain.
That would seem to presuppose that all the drivers have the same efficiency which is often not the case between a bass driver and a tweeter. I am currently looking at an application where the power output is a 10:1 ratio so 100 watts on the bottom end and only 10 on the high frequencies, not conducive to using matched amplifiers in the least.
Did I read yesterday's Facebook update correctly that the Rev-B2 with new ADC will soon be ready? Will you soon be able to evaluate your test unit with the analog input board incorporated?
- Vendor's Bazaar
- Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC project
