Hi aetosa,
I thought that this one
http://www.redcircuits.com/Page2.htm
is design for 25w only and not what you said 60w. I did asked the designer for a power boost but he said he had to redo everything. But after some years I think he did it. It's his new project 100 (on the same web-site). I have tried the old one but not the 60W yet. The 25w is easy for a freshmen. I did it without much difficulty 3 years ago.
I used 530 instead of 532
I would say
go for the IRF AN-948 application amplifier.
That 25 Watt amplifier IS NOT SAFE to build.
The IRF AN-948 amplifier is much better if you want to build your first amp,
that will work good.
Hi lineup
Would you please elaborate on why the 25w is not safe? What about the 60w at the same web-site?
This amp will be safe, but with lateral mosfets, not with vertical ones ( IRF... ), 'cos have any temperature compensation of bias current....
imho two keywords self oscillation, and temperature compensation..
it's probably possible to fix though..
and the first one has no current sources :-( ..well it will work i guess but..
hmmm I also use a similar design.. http://deeper.mine.nu/amp2/scheema3.gif .
Ok, I'll go for the AN-948 using the irf539 and irf9530. I'll let you know how it works (if it works). Thank you all for your answers. You were very helpfull.
This is an old topic, but I'm pretty sure this is the IR app note I built an amp board from about ten years ago. It did work, but it died quickly driving an 8 ohm sub in my car. I was grateful that the power supply had DC output fault detection, so the sub wasn't hurt. I was also grateful that the amp failed with a short to the positive rail, because the protection circuit wouldn't detect a negative DC fault. (This was a design flaw... examining the circuit showed that it couldn't work unless you had an unusually sensitive optocoupler.)
If your speakers are worth more than a few dollars, I'd suggest using some kind of DC fault protection circuit with this or any experimental amp. And if there's any tweaks to the circuit that will make it electrically more robust, add them.
This thread refers to a couple of protection circuits:
http://www.diyaudio.com/forums/showthread.php?postid=374316#post374316
There's also a Velleman kit, K4700 maybe?, that'll do the job.
- HEX-FET 60W/4ohm Amplifier
