Hermes-BBB/Botic cape for BeagleBone Black
Oh well.., but was it necessary to solder directly?
Also, I assume that you confirmed that your buffalo dac was identified as a slave device by the command below on i2c wire connection.
Code:
i2cdetect -y -r 1
... :sad:
I tried with headers and plugs, but I couldn't be sure that they were making good connections.
No, I've never seen that command before! Assume I know nothing about Linux (pretty much true).
I got the following response:
Code:
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I think I'll give up and reinstall the Volumite. At least I know that works (and my ears are suffering from having to listen to everything at full volume!)
Code:
Aha, your dac was not identified as a slave device, the address of which should be shown as 48 somewhere in the listing above.
Did you connect GND line between the dac and BBB? If not, try it if that will work before your ear drums are broken. Otherwise...., take care.
I don't know, but I can't believe that Russ would design something that didn't work with Buffalo DACs.
Resistance between either SDA or SCL and VCC on my Buffalo II is 2K ohms, a good number for pull-up. So my guess is that added resistance is not required. But one point - easily overlooked - did you dismount the 8 pin control chip from the socket next to the I2C header on Buffalo? I understand that is required.
Frank
