Help with small Subwoofer project
Amazingly most manufacturers put their ports on the front of the
enclosure,whether it be home or pro. Hmmm must be a good reason
for that. Makes sense to have the other 50% of total driver rad-
iation pointing in the same direction as the cone. Personal
aesthetics and spacing should really dictate where it goes though🙂
Yes they should definitely face the port in another direction,
especially if they didn't design it properly( made it too small).
Any internal mid and Hf reflections in the cabinet are usually
damped/ broken up by stuffing and bracing scheme's, But can also
come thru the cone itself if the enclosure is improperly designed
Though I have observed many fine enclosures moved away from
boundries like walls and corners to calm down the uneven/exagger-
ated response variations those spots provide for the audio spectrum.
