Help with rt-plugins-x.x.x.tar.gz
Nope
mike@mike-HP-Pavilion-13-x360-PC:~/Downloads/rt-plugins-0.0.4/build$ cmake ..
-- The C compiler identification is GNU 5.4.0
-- The CXX compiler identification is GNU 5.4.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- [CPPCHECK] Could not find cppcheck executable
-- Configuring done
-- Generating done
-- Build files have been written to: /home/mike/Downloads/rt-plugins-0.0.4/build
-- Configuring done
-- Generating done
mike@mike-HP-Pavilion-13-x360-PC:~/Downloads/rt-plugins-0.0.4/build$ sudo make install
[sudo] password for mike:
Scanning dependencies of target RThighpass1
[ 4%] Building C object src/CMakeFiles/RThighpass1.dir/RThighpass1.c.o
/home/mike/Downloads/rt-plugins-0.0.4/src/RThighpass1.c:33:20: fatal error: ladspa.h: No such file or directory
compilation terminated.
src/CMakeFiles/RThighpass1.dir/build.make:62: recipe for target 'src/CMakeFiles/RThighpass1.dir/RThighpass1.c.o' failed
make[2]: *** [src/CMakeFiles/RThighpass1.dir/RThighpass1.c.o] Error 1
CMakeFiles/Makefile2:105: recipe for target 'src/CMakeFiles/RThighpass1.dir/all' failed
make[1]: *** [src/CMakeFiles/RThighpass1.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
OK, There is some progress.
The important bit from the message above is this one:
Code:
You can get this file form may sources. I think the easiest is to install a package, that you can get from this location:
https://launchpad.net/ubuntu/precise/+package/ladspa-sdk
Download the deb file that corresponds to your CPU and install it with dpkg.
Alternatively you can download the header file from this location:
http://cpansearch.perl.org/src/JDIEPEN/Audio-LADSPA-0.021/ladspa.h
and copy (with sudo) it to /usr/include directory
F
Ok, Please verify that you have the file by typing following command:
Code:
ls /usr/include/ladspa.h
If in result you see an error message, such as "no such file or directory" then the header file is not installed correctly.
If you do not see any error message you can go to your rt-plugins-0.0.4/build directory and try to build it wit make.
Can't implement crossover
Hi all, I'm running Ecasound and can play mysong.mp3 out of the headphone socket on my laptop. I want to use Ecasound solely to DSP my sub woofer, with a Raspberry pi. For starters, I removed the tweeter section.
ecasound -z:mixmode,sum -x \
-a😛re -i:mysong.mp3 -pf😛re.ecp -o:loop,1 \
-a:woofer -i:loop,1 \
-a:woofer -pf:woofer.ecp -chorder:1,2,0,0 \
-a:woofer -f:16,2,44100 -o:alsa,sysdefault:CARD=PCH
I want to insert a lowpass filter
# woofer.ecp woofer = -el:RTlr4lowpass,1500 -el:RTlowshelf,4.0,150,0.71
I can't insert it without getting an error?
Why?
Kind Regards,
Mike
