My old but trusty B&K av5000 series ii finally let me down. One of the channels started distorting really badly. Tracing the circuit back led me to a blown Q12 2n3440. Everything else seems to test fine.
Should I be trying to find original Motorola transisters or will newer replacements from Central Semiconductor work just as well?
https://www.mouser.ca/ProductDetail/Central-Semiconductor/2N3440-PBFREE/?qs=u16ybLDytRbmQdZPnRs14A%3D%3D
Assuming if if Q12 is replaced its a good idea to also replace Q4?
Likely recap while its apart. Looking at the schematic is there anything else to inspect or replace?
Thanks!
Thanks!
A 2N3440 is a generic transistor mostly anything with the same parameters is fine. I would order from Mouser and fit the original type.
Q4 ... only if it is faulty.
Agree with Jon, I’ve replaced only that part and with the Central Semi from Mouser and worked just fine.
