Help with replacement parts for B&K
My old but trusty B&K av5000 series ii finally let me down. One of the channels started distorting really badly. Tracing the circuit back led me to a blown Q12 2n3440. Everything else seems to test fine.
Should I be trying to find original Motorola transisters or will newer replacements from Central Semiconductor work just as well?
https://www.mouser.ca/ProductDetail/Central-Semiconductor/2N3440-PBFREE/?qs=u16ybLDytRbmQdZPnRs14A%3D%3D
Assuming if if Q12 is replaced its a good idea to also replace Q4?
Likely recap while its apart. Looking at the schematic is there anything else to inspect or replace?
Thanks!
