help with diff. output
Hello -
If you choose the wrong outputs it will invert the absolute polarity of the audio signal. There is no danger, but the sound quality will be slightly degraded.
However, there is a danger if you use current-output DACs with this circuit. It will not work. This circuit is only for voltage-output DACs.
Good luck,
Charles Hansen
Charles Hansen said:
Hello -
Good luck,
Charles Hansen
Charles
some discs will suffer, others will improve
there is no such thing as "absolute correct polarity". I have recordings where even different mics have different polarity - horror.........
regards
