help with a t amp mod gone bad
Hi, welcome to the forum.
Can you give a few more details? How does it shut down? Do you get a clicking sound? Does the LED stay on? Both channels the same?
You may have a short to ground at the outputs. That would be the first place to check.
thanks for getting back to me.when it powers up there is no sound.as i turn the unit off there is music fo a second then dead.i did the mods that you supplied for the kit.i used the first set of instructions .i grounded out the right and left rca wires under the board. i think i messed up grounging somewhere can you tell me how to check it?
Could be a fault in the input circuits.
Remove the input track grounding and give it a try. Be sure that you do have a ground from the RCA to the board somewhere, though or you'll be in for loud surprise!
