Help, what kind of diode is this without any value!!
D
Deleted member 550749
D
It's from old amp like 30 years old or something, it's single signal diod used at bias section problem only only one side voltage swing, replaced with 4148 + 2.2ohm resistor and amp is working, because in market this diod not is available,
