I was frustrated getting reasonable results out of the MJK worksheets (i will revist that at some point) so we went ahead and threw together a push-push bass reflex based on the Super 8 4th order on Steve's site.
All i can measure is the impedance curve -- but i'm sure to someone more familiar with BR the shape of those 2 humps tell a lot... any suggestions on optimizing the tuning?
dave
dave
And what it actually looks like -- only the finest scraps were used...including recycled venerred particle board from some old speaker, 40-yr old plywood, the top from a console hifi, and part of a rejected table top with inlaid marquetry (currently the back of the speaker (i think i'll move the terminals to the face you see).
dave
dave
I think these speakers have potential... currently hooked up as an HT woofer only using the XO out of the decoder, each driver driven by a channel of a Don Stenton Signature SS amp (50W/channel).
Starting to break them in -- Frank Zappa's Baby Snakes DVD on ATM.
Once i remove the base i'll play a bit with port stuffing (i'm much more comfortable with aperiodic).
The HT Processor doesn't have enuff adjustment to turn them down enuff... i'll be breadboarding up some XOs to see what we can do to improve on that.
dave
dave
You dont have any driver specs? What a shame...
that bottom firing port is a bit strange, I would imagine the way it is configured like that makes the effective port longer than just the part that goes inside the box.
BassAwdyO said:You dont have any driver specs?
Driver specs are in the pdfs....
dave
Hmm, I can see why Chris never lets you loose on the woodwork! 🙂
Well, it looks like you nailed the alignment fairly well, the well smoothed first peak being very indicative of the higher order alignment. The second peak is a little wide, but that is probably due to slight differences in the drivers blurring the curve.
Is that impedance curve calibrated, or just relative?
That looks very like a good HT sub for the money, I would be a bit wary using it as a music sub, though, the group delay is "interesting", though I have seen worse.
So, when is Jason going to build your mic pre, so we can see some frequency measurements? 😉
pinkmouse said:Is that impedance curve calibrated, or just relative?
calibrated. I'm using Fuzzmeasure for OS X.
It is all i can use it for at the moment due to XO issues. Jason came out to assemble the new XO on breadboard on Sunday, but ended up watching cooking shows instead. He wanted to do it so i left it for him... i'll do it myself now.
It is sitting in a box all assembled... have to assemble the mic wand & test it... the new 1.2 beta of Fuzzmeasure has a whack of updates, but all have to do with measuring so i am eagar to see what it does.
dave
Fine Woodworking?
Sooooo, you decided to show off some of my fine woodworking. I must say you got the photo from a good angle. I am glad it is just a prototype. Maybe a can of black paint will bring the best out of that fine looking box I made? All in all it was an hour or two well spent. Besides I was just going to burn the wood anyway.
I am sure you will figure out how to make sound better than it looks. Then we can show off a nicer cabinet.
Would substituting a pair of those 8" MCM woofers work okay? Looks like a good plan for me if it will.
Joined 2002
Re: Fine Woodworking?
First he will probably Stuff the port : O ) next he should run them out side at a hi level to loosen them drivers up : O )
SCD said:Sooooo, you decided to show off some of my fine woodworking. I must say you got the photo from a good angle. I am glad it is just a prototype. Maybe a can of black paint will bring the best out of that fine looking box I made? All in all it was an hour or two well spent. Besides I was just going to burn the wood anyway.
Note to everyone -- Scott's (and Chris' for that matter) quick and nasty is typically better than my best....
(i can run circles around them both designing & drawing thou -- so it is a good symbiosis)
dave
dave
Re: Re: Fine Woodworking?
I'll be running them 24/7 once the XO is done, and i can move them off the HT setup.
dave
jleaman said:First he will probably Stuff the port : O ) next he should run them out side at a hi level to loosen them drivers up : O )
dave
Well I never did get to hear them. I guess they must have potential or you would not be wasting time on them. Once we get a design worked out I can make up a real nice cabinet. I have a few furniture integration ideas that might be interesting. How about a set of short leg end tables.
On an off topic note:
I have just about finished my monblock amps I will send you a picture in the next few days.
mateo88 said:Would substituting a pair of those 8" MCM woofers work okay? Looks like a good plan for me if it will.
Concept wise they should... actual box volume, and port size (if any) would likely be different
dave
Joined 2002
How did these turn out Dave? I'm going to build a similar design. What box volume and tuning did you end up using?
Joined 2002
I asked dave this morning as we were humping my stuff to my new place what a sutable t-line box would be for these apex 8" subs.. Has any one done a t-line for them ?
jdybnis said:How did these turn out Dave? I'm going to build a similar design. What box volume and tuning did you end up using?
Still in progress... i stuffed a handfull of poly into the port, and have been enjoying them in my HT.
Found out what was screwing up my MJK sims and will revist the TL for these (gotta do an extremis 1st thou)
dave
- Subwoofers
- help tuning push-push ApexJr super 8 woofer
