jdybnis said:What kind of cross brace did you use between the two drivers? I'm thinking of epoxying a few hardwood dowels between the backs of the drivers.
The structural brace between all the side walls was notched so that the magnets butted up against it.
dave
Greets!
Just plugging the numbers into the ML-TQWT WS I get a T/S max flat with some peaking at Fb and another program calc's a bit high vent mach, so the need to 'stick a sock in it' is understandable. 😉
FWIW, last year I took a look at this driver for someone and came up with this T/S max flat Voigt style dual driver pipe, but if they built it I never heard back, so as always YMMV:
L = 54"
SO = 1.122"^2 (physically comes to a point)
SL = 130.452"^2
rp = 2.121" (for simmimg purposes, build using dual 3" dia.)
Lp = 13"
drivers down 35.38"
It sims somewhat better damped for its much greater Vb than the BR of course, but like any max flat alignment it may sound a bit 'one note' in-room with this low an Fb, so I recommend bottom firing and possibly some vent damping for it also if near a wall or corner.
GM
L = 54"
SL = 130.452"^2
Lp = 13"
drivers down 35.38"
GM
