Help: Soft dome tweeter pushed in
I have pulled plenty of domes back out with a vacuum cleaner.
The trick is to disconnect the hose from the vacuum cleaner and turn the vacuum cleaner on first.
Position the entrance end of the hose over the dome with an air gap and CAREFULLY hold the other end of the hose partway into the vacuum cleaner so as to regulate the suction produced.
NEVER allow the full suction to be applied.
If the magnet is detachable, the other method is to remove the magnet and press the dome back out from inside the dome.
Eric.
