Help - pre ARC
Thanks Steve
Update : I have changed the four 6h30 in line section and now the noise is greatly improved
This objects are strange , in my pre volume not influence hiss , even at max level .
The volume is ahead the output circuit so the noise is always there even the pot is at max attenuation
As I wrote you it is a tube issue
The 6h30 and 6n6 need to be well selected also for noise floor, micro phonic and gain
Walter
