I try to avoid the worst of those drivers.
IMO BSC is overused and over recommended It has a place but...
dave
dave
For what it's worth I preferred the metal cone MA over the paper cone variety. My response was virtually identical to what Bob Brines said about the paper cone versions some time back.
Thank you for all the replies. I want to correct something from the drawing. That is the speakers location. I have them 50cm from the wall.
I will first decide if I go with the paper cone or the magnesium cone.
There is a design out there where I can use both alpair 10p vs 10.3.
I might try the 10p first and if I dont like it.. purchase later the 10.3..
Most designs work for both, sometimes you need to adjust the portlength. I only tested my design with the 10.3, but sims say that the 10P should also work very good in that.
Dave, do you happen to use BSC on any of these two?
Please recall my correction regarding the distance from wall to speaker: 0.5m
Other thing I saw in the specs is that the 10p has lower impedance curve. Perhaps more suitable for my 8 ohm amplifier output?
Thanks again for all the suggestions.
Not having heard them i cannot say. Where they are placed in the room and what your taste is.
I have never had to use BSC on any of my miniOnkens.
dave
dave
when I said.. "on any of these" I meant on any design you end up using the 10.3 or 10p.
Already answered though.
Thanks.
Thanks.
certainly in your case i would not install BSC as you have only a few watts to spare and need the sensivity. And in such a small space (i have a similar space) room will add enough bass, even when they are 50cm from the wall. I use mine against the wall (back is 10cm from wall or so) and never used bsc in mine.
Hello,
sorry for stealing your tread Emartine, but I'm having roughly the same question:
living room roughly same setup and dimensions. Planning to put small (bookshelf / monitor size) speakers on closet with their backs very close to the wall. Driving them using a small SE tubeamp.
Listening to lots of different kinds of music: classic, rock, metal, bit of pop / dance.
I'm thinking of some Markaudio drivers, for example CHN110, but on the fence for an maop version. Would it be worth it? Any suggestions for cabinets (skilled woodworker so like to make them myself)
Thanks in advance, Bill
Bill,
I have not heard the MAOP, but Leif & Robin seem VERY happy with theirs. CHN-110 is band for the buck, but i expect less resolving than the MAOPs.
dave
dave
work and family life took quite some time in the past weeks but I managed to listen to a lot of drivers. In the end I'm going with the CHN 110.
Found the FB41-24 DF and FB40-30 DF building plans but am afraid those are sensitive for the placement close to the wall. Any thoughts on this / alternative cabinets in this size?
Cheers, Bill
Cheers, Bill
- Full Range
- Help me choose a fullrange speaker
