Help identifying u600 on jl audio 500/1 amp
Its rev 10
U600 is a thermistor. They do not burn unless something burns them externally. If that had happened, there would be burned material all around it and I don't see any.
If you want to learn and do what's required to learn how to test components, I'm willing to help. If you simply want to blindly replace parts that are almost certainly OK, I'll let others help.
