good day sir/mam
help with my power amp always protect removed driver board normal green lights when i come back protect again i change output as well as protect again
there are buyable protect driver boards do the driver board have parts what is the value of the parts
thanks in advance
thanks in advance
There are 2 transistors on the driver board that fail .
Take a pic of the driverboard and post it on here and I will tell you what 2 transistors you need to replace and give you the part numbers
Collector - Base Voltage
VCBO
300
V
Collector - Emitter Voltage
VCEO
300
Emitter - Base Voltage
VEBO
5
Collector Current - Continuous
IC
500
mA
Collector Power Dissipation
PC
350
mW
Thermal Resistance Junction to Ambient
RθJA
357
°C/W
Junction Temperature
TJ
150
°C
Storage Temperature Range
Tstg
-55 to 150
■ Electrical Characteristics Ta = 25°C
Parameter
Symbol
Test Conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
VCBO
Ic= 100 μA, IE= 0
300
V
Collector- emitter breakdown voltage
VCEO
Ic= 1 mA, IB= 0
300
Emitter - base breakdown voltage
VEBO
IE= 100 uA, IC= 0
5
Collector-base cut-off current
ICBO
VCB=200V, IE=0
0.1
uA
Emitter cut-off current
IEBO
VEB= 5V , IC=0
0.1
Collector-emitter saturation voltage
VCE(sat)
IC= 20 mA, IB= 2mA
0.2
V
Base - emitter saturation voltage
VBE(sat)
IC= 20mA, IB= 2mA
0.9
DC current gain
hfe(1)
VCE= 10V, IC= 1mA
60
hfe(2)
VCE= 10V, IC= 10mA
100
300
hfe(3)
VCE= 10V, IC= 30mA
60
Transition frequency
fT
VCE= 20V, IC= 10mA, f=30MHz
50
MHz
■ Classification of hfe(2)
Type
MMBTA42 MMBTA42-L
Range
100-300 100-200
Marking
1D
VCBO
300
V
VCEO
300
VEBO
5
IC
500
mA
PC
350
mW
RθJA
357
°C/W
TJ
150
°C
Tstg
-55 to 150
Parameter
Symbol
Test Conditions
Min
Typ
Max
Unit
VCBO
Ic= 100 μA, IE= 0
300
V
VCEO
Ic= 1 mA, IB= 0
300
VEBO
IE= 100 uA, IC= 0
5
ICBO
VCB=200V, IE=0
0.1
uA
IEBO
VEB= 5V , IC=0
0.1
VCE(sat)
IC= 20 mA, IB= 2mA
0.2
V
VBE(sat)
IC= 20mA, IB= 2mA
0.9
DC current gain
hfe(1)
VCE= 10V, IC= 1mA
60
hfe(2)
VCE= 10V, IC= 10mA
100
300
hfe(3)
VCE= 10V, IC= 30mA
60
fT
50
MHz
Type
MMBTA42 MMBTA42-L
Range
100-300 100-200
Marking
1D
Then something else is defective on the driverboard of you replaced the 1 D transistors on the driver board all ready
Any one help me my driver board ��
Post a photo of your driver board.
The top op-amp sometimes fails.
The thread appeared to go offline with information being given off of the forum so I ignored it.
- General Interest
- Car Audio
- HELP Hifonics Brutus BRZ1700D.1
