Hi everyone. Yes, i did search help topics but , a lack (or too much) posts,
did not help me.
I would like to build a Pass class A power amp, around 60plus wpc ( A-75 maybe?), and need help with, where to get the printed circuits boards, components (digikey?) heatsinks? output devices,etc, i'm from Quebec Canada...
I looked at all those project pictures (nice builds in there guys!), and did not see
vu meters... I'd like to install BIG vu meters on mine, any ideas on where to get
those? (a la SAE, Yamaha, Macintosh etc, etc...)?.
Pierre
did not help me.
Pierre
Big, LED projection VU meters, like these?
As your first build, you might want to consider an F5. They do not have the power output you suspect you need, but this amp is a relatively easy project, and a great one to give you experience in the Pass Class A philosophy, topology, and all-the-other-"ologies". It's a stellar, uncompromising amp...!
60wpc into what load? A Burning Amp 3 or F4 will easily scale to that into 4ohms....
Into "low" 4 ohm... Did not build or even simulate the speaker system that are going to be matched to this amp yet.
Where do i get those boards?. This is getting exciting
Roscoe
Don't know about the boards, or understand why everyone here thinks they need boards...
Perfboard and point-to-point are great solutions for circuits as simple as these....
Roscoe
Roscoe
What if i want a clean, pro looking assembly with proper boards...
Looks like a secret well kept, finding those boards😡
Peter Daniel has the Aleph-J and F2 boards
http://www.diyaudio.com/forums/private.php?do=newpm&u=2018
F4 and F5 and BA-1, BA-2 and BA-3 boards in in the diyaudio store
diyAudio Store
ask suds for F3 boards
http://www.diyaudio.com/forums/members/suds.html
and look at First Watt page
F5 turbo and F6 is coming, maybe boards will come in the store....
FIRST WATT WATT'S NEW
diyAudio Store
Hey! thanks guys! now, i am asking for one last effort: where are those
power supply (cap.) boards? .
Did not find them yet.
I am going to use this opportunity to wish you all a Merry Christmas!!!..
Same here, first time diyer, looking to make an F4, how do you go about making the psu. Also, which components need heat sink ?
Thank you and Merry Christmas and a Happy New Year to all !
chipamp.com. bottom of site Order | Chipamp.com
it is a nice CRC/CLC PSU. it supports 6pc 40mm caps, bleeder resistors and bypass caps.
There are literally hundreds of threads about DIY builds of all the Pass DIY amps.
Heres one from last year.
http://www.diyaudio.com/forums/pass...-diy-project-build.html?highlight=Aleph+Build
he was a pioneer
I've never seen a bad review of any Pass DIY build.
It all depends on how much you want to spend and how confident you are.
Matching the MOS-FETs is arduous, the more you need matched, the more arduous the task. Pairs are relatively easy, Triples not too bad, The Aleph P4 uses Sextuplets - not a mean task - and you need lots of devices to pick from.
I've got 24 IRFP244s left from my matching process - anyone can have the lot for £24 GBP plus postage.
Most of them make good pairs and even triples - I will supply the data that I obtained when matching mine.
- Help getting started with Pass DIY amp.
