Help for Virtual Earth Mixer project
Hello everyone, I built the mixer, it is working but there is a problem:
as you can see in the schematic, every input goes into two volume pots (and to separate outs), when the pot controlling output 1 is completely turned down the volume of the output 2 is very weak (even if the relative pot is at full volume), if no pot is at minimum each channel is playing at the right volume.
Any suggestion on how to solve it?
Thanks a lot!
Wow, that's a stumper!
If one pot is already Minimum, does the output level drop again if another pot goes from Maximum to Minimum?
The only way I can think of producing that symptom, would be if you've swapped the Full-CW pin, with the Wiper pin, of the turned-down pot.
Cheers
Sorry Rick (and everyone else reading), I realize now that the question wasn't clear at all, my fault!
All the pots are wired:
Pin 1 to ground
Pin 2 to input jack
Pin 3 to circuit board input
This is the issue:
Let's say pot1 controlling input 1-2 to output 1-2 is at maximum level (or somewhere in between) and pot4 controlling input 1-2 to output 3-4 is at minimum there is no sound at output 3-4 and very weak sound at output 1-2. If I raise pot4 a little, everything is working correctly.
Same thing if pot4 is at full level and pot1 is at minimum.
The other pots are not affecting that channel, but they have the same issue on their relative channels.
Thanks! I already done that yesterday, and everything is working, here is a picture of the finished work, I really like it, and will be super useful for my future live sets!
Thanks everyone for helping, looking forward to dive in a new project and hopefully learn something new!
