My new preamp, an Electrocompaniet EC-1, have one noisy phono channel.
Not hum, but cracklings...
In order to solve this problem, I would like to find schematics, diagrams, ...
Of course, I asked that to Electrocompaniet Norway, but without success.
And I am not astonished by this no reply ; all companies are doing so, except AUDIO RESEARCH !!!
Perhaps You are able to provide help ?
I hope
Raymond
My EC-1 :
I hope
Raymond
My EC-1 :
You could ask Mr. Abrahamsen who started EC, and now runs his own company Abrahamsen Audio.
Abrahamsen Audio | H e a r i n g i s B e l i e v i n g
Halols, mjf and Gorgy, THANK to You !!
- I will try today or tomorrow to contact sir Abrahamsen but without good hopes because my English is a bit poor ( if I was Norwegian like you it will be more easier with phone to get a nice reply !! ).
- on DiyAudio, nothing appear about EC-1 ; only one other guy, like me, is trying to get schematics.
- Of course, I verified before all electrolytic C and changed all these out of specifications ( around 16 C 22µF/63v were so ! ) but no amelioration ; in addition with a magnifying glass, no dry solder found.
This is why I am searching then schematics for understanding circuitry !
Raymond
Raymond
Thanks Andreas for your informations !!!
But alas, nothing on them abour EC-1 preamp.
Raymond
if i understand correctly it is only one channel of the phoneamp that is crackling.......
annother reason for that can be a bad contact........the source switch,can be cleaned with a contact spray or so...........
greets
Thanks mjf for your interest.
Crackling become visible ( with oscilloscope ) in the middle of phono stage ( the right channel only ).
Then, no problem with source switch, volume & balance potentiometers.
In this case, only diagram can help me
Raymond
hello.
can you give a little pressure (with your fingertip) on the bad channel so that the pcb is a little "bent trough"............if then the crackling changes it should be a bad soldering point or hairrent or bad contact..........
Ooooh !
Of course I do that, little pressure and small bumps on pcb and on all components one by one located on this phono channel.
And resoldering all questionable...
Raymond
ask additional there
HIFI-Studio Wittmann in Stuttgart: Nehmen Sie Kontakt mit uns auf ... (Service Center Electrocompaniet Germany)
audiocostruzioni.com
and by this private sellers:
Electrocompaniet "EC-1" Preamplifier - Canuck Audio Mart
Electrocompaniet pre amp EC1 (Used)
Electrocompaniet preamp - help requested - AudioKarma.org Home Audio Stereo Discussion Forums
because in early days electrocompaniet release the schematic in general (together with the owner's manual).
A formerly employer from EC had a website some years ago with all their schematics online. But Electrocompaniet say, all schematics must remove. I don't know his name. Perhaps an other guy know this. Then you can try also ask there.
ask additional there :
Many thanks Andreas, I will contact all !!!
Yesterday, I repaired it with an enormous lot of chance.
They were not at all bad electrolytics, semi-conductors, soldering, switches, potentiometers, ...
Only in need of adjusting DC offset voltage in phono circuitry ( don't ask me why, I have no diagram for understanding that !!!!!! ).
And now phono stage are very very quiet.
Here my EC-1, top plate removed :
And below a pic of the 2 phono stages ( on the left, from upper to below, the left phono channel ; and on the right, the right channel ) :
The trick is to adjust ( after the warming delay ), with the help of the 2 red trimmers ( for left channel this one just below "R78" lettering ) 0.0volt on the ouput ( this one just below "R63" lettering, for the left channel ) of this one ( the 4 blue "Siemens KP100000H" capacitors ). For the right channel you have to choose the opposite on the extremly right !!!
But I still woul like to find schematics for understanding that.
Raymond
Dray177, maybe you could back engineer and trace us that circuit, I would love to see the schematics too, from your pics I can see lots of high quality parts, products from this company usually have exceptional sound quality. Ive got a couple of amps from electrocompaniet but no preamps, if your ever in future think of selling it drop me a line, your preamp looks like you took good care of it and is in perfect condition.
I am not skillfull for re-tracing circuit ( indeed very complex with many semiconductors ).
But, me also, I would like to have this diagram on my table.
And you are right, now, this EC-1 looks like as new
My Son wish for comparing it with its Kenwood L-07CII preamp, associated with a very nice THRESHOLD Stasis 3.
Restored it also, last month
Its Stasis 3 for repair :
And now :
It will be easy to reverse the circuit if you publish a similar photo of the solder side.
Oooooh !
I don't think so, not at all easy with these recto-verso PCB.
And there are a so great number of components.
I tried a bit in order to understand and solve my problem, but I losed my way very quickly.
In this case the best is to use an oscilloscope for tracing the noisy signal...
Raymond
supplement to my post #12:
Now I have found the name of the formerly EC man and his own homepage:
The Sandstrm Audio Site
please contact Terje@osiris.no
Actually he must have the EC1 schematic in the PDF format
Two years ago he send me this reply:
"Hi ! Regretfully current policies at EC says that the schematics shall be not made public. They are therefore also removed from my site, even for the older amplifiers. This may of course be changed in the future, but I have no timeline on this. Best regards Terje"
... ...please contact Terje@osiris.no
Thanks again Andreas, You are the best !
Raymond
- Help !! ELECTROCOMPANIET EC-1 preamp
