I also noticed it doesn't happen if the tone controls are set at 50% or lower. If you turn up the treble it starts to happen when the treble control hits about 80%. It happens almost immediately if you turn up the bass control past 50%.
Something in the tone control? According to the block diagram all the signals go through that board before going on to the pre-amp or power amp.
I'm going to dig into that circuit a little.
I just haven't let it sit for very long. It's out in the unheated garage. I can turn it on and let it sit for a few minutes and see if it heats up.
As for power supply, I'm using the power supply I listed earlier. I can try just using a car battery as well, I have a few spares.
O)r, you could have just wrote what the supply was.
When an amplifier IC like the 8215 fails, they often get hot very quickly. In less than a minute, you generally can' hold your finger on the back of the IC.
Is the voltage on either the acc or BU terminals of the radio dropping to less than about 10.5v?
Sorry about that, I was trying to avoid waking the kid running up and down the stairs. The garage is down 2 flights, and it was late.
Power supply is a TDK_Lambda JDS-150/12A. I believe it's a decent unit, and this hasn't happened when testing other head units.
The deck warms up as usual. Ironically the lights up front are the warmest part. The power amp is under the heat sink at the back, and that's getting warm, but not hot.
I will check the acc and BU terminals later today, and I sent an email for the repair manual.
Last night I also checked the voltages at IC2, the tone control IC. And they are all way lower than they should be. The manual says they should be 4.3V on 6 of the pins, I'm reading 1.5V with pulsing on pin 2 and 6 from about 1.3 to 2.2V.
Unforunately the probe on my scope seems to be going bad, so I might need to pick up a new one if you have any brand suggestions. The output on the scope was flickering last night if I wiggled the wires on the probe, this morning it's barely working at all. Ugh.
The probes are not critical, for the most part, for car audio. There are probes on ebay that sell for 4 for $25. They work perfectly fine for this. Search for:
4 100MHZ Oscilloscope probes
Ugh, it looks like my scope problems weren't probe related. I'm not getting a trace on the screen unless I flick it on and off quickly.
I'm bummed, I don't need another project right now
Yes. I tried auto. I couldn't find the instruction manual for the AWS 315P, but I found one for a found the instruction manual for the 620C which is from the same timeframe. I followed the initial setup instruction and don't get anything on the scope.
I did notice previously that I only got a dot on the scope when the sweep time was at the fastest setting. Maybe that area is the issue? I just don't have a ton of time to play with it right now, I have a big race in 2 weeks and I'm focused on getting the racecar done.
Don't throw the towel right now, a scope can seem dead if you touched the wrong setting. Allmost any time I start it after some time away from it, I think it broke down...
For the radio I make a guess: Some of the preamp stages are running on stabilized power. This supply has a problem and when you pull a few more miliamps it collapses. That may give you the bass/ tremble dependend on/off bump. So try to check these voltages first. It may be a dry cap or faulty regulator.
These old radios can be repaired, as they are "quite" simple.
Nothing like my problem... I have a drawer full of "Becker Mexico" radios, the best and most expensive ones you could buy in the 90's. They all worked well when the vintage cars (Porsche, Mercedes and Ferrari) went into storage. About 8 years later, when the cars were reactivated, none of them works any more. The EPROM containing the programming seems to have lost it's contend. All got the exactly same fault, Becker as a company is gone and no scope or soldering iron is going to fix this.
Vielen dank! I'm not throwing away the scope just yet, but I'm taking a break from it and going back to my DMM.
I checked some voltages on different ICs tonight, to try to get a feel for how the signal moves through the circuits. I will keep checking when I get time. I'm definitely finding some voltages that are around 1.5V when the spec says 4.3V, so now I need to work back and figure out where that is happening.
It would be tragic to see you go from an analog scope to a digital scope with a far inferior display but that's what generally happens. Hopefully not here.
Nope, not going to a digital scope. Just hitting a point in my project/stress curve that's less than optimal. LOL
My scope came back to life, just dirty switches that needed cleaning. I'll get back to this project after the ADS amp I'm working on, and after I finish Perry's tutorial.
I'm back at the Kenwood. I'm waiting for parts for the ADS amp I'm working on, so I thought I'd look at this again. Perry I see why you don't recommend fixing head units. So many tiny components, and a couple boards oriented where I can barely get access.
But it's still an interesting challenge.
So I decided to try to trace the signal path through the unit. It still pops or drives +10V, then negative 10V DC voltage when I turn up the tone controls past a certain point.
So I looked at all the voltages at the chip on that board, IC2. They were almost all too low. So I looked at what was feeding it, and found the 1/2 VCC voltage was way lower than I expected when I unplugged connector CN21 on that board. I only showed 1.195V.
(re: my notes, the voltages inside the chip are from the manual, outside the chip are my measurements)
I tried to follow 1/2 VCC back through the unit and came to board X14-C3, with the ISO, 1/2 AVR and Pre Buffer chips on it. IC7 looked close enough, but a couple voltage measurements on IC6 looked low and almost all of them on IC5 are low.
At this point I am trying to figure out what to check next. Is chip IC5 bad? Or is there a component near it that's bad and pulling down these voltages?
Perry you asked if the main power chip was heating up, and yes it heats up, but slowly. Using an IR temp gun I can see it slowly increase the temperature, but it's not getting so hot that it's hot too touch.
I did find one resistor on the bottom of the board that gets really hot, but I believe it's in the illumination circuit so I'm ignoring it for now.
I'd love any suggestions on what to check next, but I'll be back looking at it again tonight while I'm also still working my way through the tutorial.
Thanks!
Thanks!
It looks like either IC6 is defective or it's output is being dragged down by C66(? can't really read it) or possibly being pulled down by something else connected to pin 1/2.
- General Interest
- Car Audio
- Help diagnosing issues with Kenwood KRC-503
