I have a 15V trafo 30W, which of this 2 amps kit are better?
Dual 12 18V A1 Headphone Audio Power Amplifier DIY Kits Based on Beyerdynamic | eBay
DIY Kit of Class A Headphone Amp Board Pre Amp Dual AC12 15V Based on JHL Hood | eBay
I've built a couple of these and they sound quite good.
AC15V DIY Kit for Headphone Amplifier Board Reference Lehmann Circuit Design | eBay
Also, member rjm(Richard Murdey) offers a kit for his Sapphire headphone amplifier that's pretty popular.
RJM Audio - Sapphire headphone amplifier
I read something about that... what other choice's do I have to go along with the 15 volt trafo?
gonna use DT770 250ohm on it.
Even if an amp has a low offset it would still be prudent to use a pair of coupling caps on the output, or better still, a transformer. You don't want to lose your expensive cans from a failure of a relatively cheap headamp.
