Help choose a pot for a passive preamp
Hi
I want to install a pot to use as a passive volume control between a Cambridge Audio DACmagic 200m and a Aiyima A07 integrated amplifier.
The DAC has an output impedance of 50 ohms (I am using the unbalanced outputs).
The amplifier has an input impedance of 23kOhms @1kHz.
What makes my question slightly different is that the amplifier is mounted out of sight in a case (with a dedicated power supply), and I want to leave the integrated volume control at circa 50% so that kids cannot blow my speakers. I do not want to use the DAC volume control for separate reasons.
I am just going to use an APLS blue with less than 20cm of interconnect cable each side.
What value pot should I use?
