Its inside of the retractor relay box of this old car. The diode in question burned in half Cathode is Pin 14. Anode is pin 17. Nothing else is connected to these pins.
Looks like its used as part of a switch to activate the fog light relay, but only when the headlights are ON.
I believe the Fog relay was bypassed and the diode could not supply amperage to the bulbs.Should not blow, check why it did...
Are you saying that this is a board that was new and it failed immediately when it was first used?
The diode and traces aren't large enough to be used for any high current circuit.
It was brought to me not working with an amp service. I’ve talked to the owner about it. Sounds like the relay was bypassed
- General Interest
- Car Audio
- Hello identifying diode
