Heatsinks
Sounds good to me. I would in any case use a heatsink which, by itself, is a little over-rated for the task, and apply heatsink grease to any mating surfaces.
I meant ''by far best'' in a practical sense, not familiar with examples of vacuum insulator use in real life.
Ah, I was taking it literally. Like a dewar or Thermos brand bottle.
By mounting the flat (rear) part of the hs against the chassis, you are insulating the flat part of the hs with the steel and losing that much hs area that could be used for cooling. Can you offset the hs with some spacers to open a gap in there?
Well, I've had one of the F5 modules running for about ten minutes, it's getting late so I'll continue in the morning, the heatsink didn't get above cold.
I'm sure it will warm up after time but the initial indications are that they should be sufficient.
