I have tried a couple of those Hdmi audio extractors, if the audio signal from the hdmi cable is 96Khz or 176.4Khz, the de-embeder outputs always 48Khz on the coax spdif output.
Have anyone tried one that outputs audio at the same sample rate as the hdmi input?
Its a sony bluray player. I verify with a friend's Dac, that the sony output the correct sample rate (pcm), I have reach up to 192Khz. But with the converters I only get 48Khz maximun.
Playing files from a hard drive.
Bluray player accepts a hard drive?
Anyway, HDMI receivers can communicate with the HDMI source device for the source to do audio sample rate conversion. Don't know if that is what is going on here.
Lots of people come here asking for 5.1 or 7.1 digital audio extraction from HDMI. Nobody ever finds a solution because the data is encrypted.
Thats fantastic! A little bit expensive for me now. If you know about some cheaper one, let me know, rhanks.
For the cheaper ones can you provide names & model numbers or links?
If you can do without multichannel audio then the GeerFab will get you 24/192 and DOP. It is however expensive. There also seem to be some cheap extractors that are not HDCP compliant and will do 24/192 SPDIF.
RIP the BD to an Hard-disk. You'll then play the tracks on the PC SPDIF or Coax out.
I'm sure a cheap or non DHCP compliant extractor will downgrade the quality.
BD was developed with anti-copy protection in mind.
The Monoprice Blackbird 4K seems to work with all sample rates just fine:
Monoprice Blackbird 4K HDMI Audio Extractor, 18Gbps, HDCP 2.2 - Monoprice.com
- Digital Line Level
- Hdmi to Spdif converters. No the same output as input
