Hawksford output error correction circuit?
amplifierguru said:
Why is your design needing error correction when regular NFB techniques can give you vanishingly low THD? You must ask yourself this.
Hello, Greg
Interesting point.
Lots of NFB will not linearise crossover distortion, and this proves it's not the universal panacea.
So, looking at how much an error correction costs (specially if one already have 2 transistors in the bias circuit), why not to use it?
Besides, it helps a lot with crossover disto...
Then apply lots of NFB to a blameless layout.
Jorge:
If it is primarily crossover distortion that you want to eliminate (or at least markedly improve), you don't need anything as elaborate as a Hawksford-style error correction circuit.
To mention a possible starting point, even one of the early Marantz transistor power amps (I think it was the Marantz 15 from 1968) had an output stage that ventured in this direction.
hth, jonathan carr
JORGE
"Lots of NFB will not linearise crossover distortion"
Sorry, misconception. NFB linearises crossover distorsion as it linearsies any non-linearity in the fb loop. Just it can't completely remove it as it necessarily has a limited amount.
~~~~ Forr
PMA
"global NFB creates new high order harmonics, that were not present before application of global NFB."
Even without NFB, any non-linearity, giving intermodulation, adds harmonics not present in the input signal. See Peter Baxandall's papers on the subject of NFB. This is one the first thing to do when speaking about NFB and harmonics.
~~~~~ Forr
forr said:
JORGE
~~~~ Forr
Ok, will not reduce enough...
Hi All ! Can my schematic correct distortion ?
impedance output of VAS is 100V/11mA , is it right ?
I tried to simulate with many values of R25 but distortion can't be zero ,in a range of 2mV to 3mV , even higher than without correction circuit
thank you !
I think that R25 only sets bias of predrivers and has very little to correction itself
The resistors of 1 ohm are probably in inappropiate place: collectors of EC should be joint to bases of predrivers. 1 ohm is very low value too 😉
try to experiment rather with 22k resistors than R25 and parallel with two 560R thete should be a biasing pot.
regards
Hi dimitri ! There are no good result ,
Perhaps that formula can only be used in the Hawkford 's schematic which has no R25 .,
Are there any one like Halcro's schematic ? I'm studying his schematic but it is too hard
