Lots of DSP amps out&about.
Are you going to build 1 or 2?
DSP is very nice to have, and especially for subs.
Here's a plate amp if you're happy with 1 sub, if you're going to build 2 then I would suggest getting a stereo DSP amp of some kind instead.
Dayton Audio SPA250DSP 250W Subwoofer Plate Amplifier with DSP
I am going to build two subs. They are going to do double-duty as stands for my bookshelf speakers. This is what's limiting the measurement to about 12x12x26 inch, or 30x30x68 cm, for you metric people 🙂
Thanks for the tip. I'm going to take a look at the amp.
If you want two subs, on a budget, then I would use this amplifier instead.
Crown XLS 1002 DriveCore 2 Power Amplifier 2 x 350W at 4 Ohms
Some people like the Behringer amps, but you probably have to modify the fans on some of those.
