Have a smoking 60-0-60V transformer and looking for a project.
I have this great big torodial transformer whch is encapsulated and and has built in thermal shut off. I have no idea what VA rating it has but judging by its size it would be at least 400VA. I cant seem to find a circuit to take advantage of it, any ideas?
By the way I can lay my hands on another for peanuts.
Shoog
Suggestion 1:
Buy a Tripath module in the TDA10XA series and build one hell of an amp for subs etc.
Suggestion 2:
Build the most overpowered BoSoZ in the crowd.
Suggestion 3:
Build an Aleph P just as overpowered as the BoSoZ. If the transformer is not center tap but dual secondaries the dual mono is nice.
See www.sealelectronics.com -- you could do a very nice OptiMOS amp with 85V rails.
Lucky guy
maybe you have a balanced isolation transformer from these guys:
http://www.equitech.com/
They make stand alone models down to something like 500VA, and are a great answer for cleaning up line noise. These things are used in alot of broadcast and recording studios for achiving the lowest mains noise. Look in their Technical Papers/Articals section for lots of info. I want one!!!!
Tom
Just buy the boards. $64 for the pair. The parts list is a little different for the 400w version. You should be able to locate the rest of the components quite easily as he doesn't use any exotic hard to find parts in any of his designs. I'm building the 200w version with the 400w to follow....Brad🙂
