0.1A can not make 78L05 hot. Have you measured actual current? Have you tried putting heatsink on it?
If you don't mind a bit of switching, a buck converter module:
https://www.amazon.co.uk/Converter-3-2V-40V-1-25V-35V-Adjustable-Regulator/dp/B07K2D1GJB
100E 2W drop resistor to drop input to about 9V...24 is too much for 7805.
Change value if needed, the regulator should get 7.5 to 9 V input.
And use a heat sink...or attach to case, use case as heat sink. use isolation to ground if needed.
Should work, provided the BT module is less than 500mA load.
There seem to be two threads with same poster and same title...
I just posted on the other thread, put a drop resistor....
Mods?
Mods?
How ?I just posted on the other thread, put a drop resistor....
Mods?
I need something super miniature (like a 3-pin chip). Will B2405S or RS7805 fare better ?
Is 100 ohm 1/4 w enough ?+24 -> 100E resistor -> input pin of 7805.
That means in series.
Simple.
How about 78M05 ?A 7805 will be better if you are near the dissipation limits of the L version. It's a bigger package and can dissipate more heat. If you are close to the 100ma limit for the L type then you should do this anyway.
For 1.9W dissipation, super miniature = super hot, bigger = not so hot, heatsink = reliability.I need something super miniature ...
- Power Supplies
- Have 24V need 5V 0.1A. Works fine with 78L05 (right size) but gets too hot. Smallest cool alternative ?
