very seldom...
as I have said in symef thread I really like the mid and low of this amp.Usually when I listen to music its the high cut filter I always adjust.
I really need this circuit coz not all music are recorded on the same level.I need some adjustment to suit my taste but it should not be often.
It would be excellent if you could ad some adjustment for the mid.😉
regards,
drowranger
regards,
drowranger
Hi Harrison, the FFT is just too good to be true, there is not a single harmonic, zero, nothing. I think you just created the most linear amplifier the world has seen; THD = 0%
Hi Qmara,
The preamp could be modified for NE5534. However this may also require addition of capacitors in some places to prevent the potentiometers from being 'scratchy'.
This model is not optimized for a mid control. It is optimized to avoid mid-band interaction.
kind regards,
Harrison.
kind regards,
Harrison.
Hi Drow,
Thanks for the link 😉 . There are many award winning speakers featuring a 2nd order passive filter.
Drow let me paint you several pictures
This preamplifier is very different from the Behringer mixer, it is not meant for a mid control. For your car if you have subwoofers in your trunk, your equilizer or head unit or amplifier unit has that option called bass boost, where you get the woofers to grunt for you and you get those looks from the side walks 😉. Thats how the bass control works.
The treble adjust your high shelf to cater for the color you want from your highs. Whether it be the spray from waves on the summer sea shore to the monsoon rain.
The bass boost behaves exactly like the bass boost used at the studio to record your music 😉 . With this preamp you are one step closer to the real thing.
Well what a picture. I do actually need ears to tell me whether the dream and reality are one
kind regards,
Harrison.
kind regards,
Harrison.
thank's Harison,
did u have other good stereo preamp with volume bass, mid and trebel (pcb layout + schema), or maybe more complete stereo preamp with simple frequency control adjustment for bass, mid and treble ? thank you
regards,
Qmara
regards,
Qmara
Hi Qmara,
Two of these preamp s give you a stereo version. I have not included frequency sweeping. The curves are optimized to give you a pleasant experience. This preamp is intended for playback at the customer premises. The requirements for recording are different.
There are many solutions on the market for what you are looking for.
Do try this preamp and post your experiences.
kind regards,
Harrison.
kind regards,
Harrison.
decoupling cap.
Hi Harisson,
can I remove the other decoupling capacitor in one channel and increase the value coz I'm making the pcb for two channel.
regards,
joel
Hi Harisson,
regards,
joel
Hi Drow,
Keep them on. You can use smaller values ie 100NF but ensure you have a larger cap lets say 10-100uF on-board not far from its smaller buddies.
Regulate the supply and use an antistatic wrist strap when handling those beauties.
Thanks for going for it.
kind regards,
Harrison.
kind regards,
Harrison.
pcb for the HAL preamp.
Hi Harrisson,
Can you review my work especially the schematic.if no error I will make for the power supply.part name is the same as in your schematic.
regards,
joel
Hi Harrisson,
regards,
joel
Nice progress Drow,
You could have the volume and gain pot as logarithmic, while the tone pots are linear. High quality pots are more expensive but last you long.
kind regards,
Harrison.
kind regards,
Harrison.
Hi Joel,
Logarithmic pots try to model what the ears expects to hear when you turn the pot. They are marked with letter A.
Linear pots have a linear response in relation to turning the pots. It would be nice if you could get ones that have the center marker. Linear pots are marked with the letter B.
Cheers 😉
Cheers 😉
- HAL PREAMPLIFIERS
