GZTA 1.1200
What is the IC in the black square in the image below?
Okay the original Q12 broke when I took it off the board. I don't have a new exact that kind of transistor so I replaced it with some other transistor wich had a collector current value high enough. I don't know if it works like it should but now there is only 2,1VDC between pins 7 and 14 on U108.
It seems like the Q12 is supplying 12V to U108 and driver IC, there is only 3kohm resistance between Q12 emitter and U108 pin 14.
Tested to take Q12 emitter leg out of board and there is 12,68VDC output. And if I solder it back to board the voltage drops to 2,1volts and is heating. The burned 10ohm resistor reads still 10ohms.
So into my eyes it seems like something after Q12 is drawing current and pulling voltage down. Also I may be all lost here too 😀
