Guitar bass amplify
First, I have no clue what I am doing. I want to experience making this thing.
I posted a question to build a 2 cubic feet Bass Cabinet to fit Emminem 15" 300 Watts 8 Ohms. With all resposes, I decided to build a closed box with
H: 21 Inches
W: 20 Inches
D: 12 Inches
By calculation (outside), the box will have 2.19 Cubic feet. I assume this side may suit my need since the speaker and braces may reduce some internal volume (The important matter is I don't know how measure the speaker and the braces.)
I am close to finish building the box. Then, I have another question:
1) Is it possible to look for (to buy) a driver to use with my newly build box?
According to the speaker emmenem 15" 300 Watt 8 Ohms spec, I need a driver with the power of 300 watts, rigth?
2) Is there a away that I can build this driver?
Thank
I have got all my material and starting putting thing together. Could any one give me instructions of how to wire from woofer to input jack.
the woofer comes with two plugs (connections) - Red and Black. the input jack comes with three prongs.
The cabinet you've made will be suited for the Eminence driver it's designed for.
Other drivers may still work in it, but the originally intended driver would probably be better.
Chris
You want the tip and ground connectors. On a socket, these will be at opposite ends. Connect the black from the speaker to the connector nearest the hole, and the red to the one at the other end...
If you don't get that explanation, I'll draw something up...
Chris661,
Thank so much for all yous instructions. Honestly, I am confused. Could you please provide draw or image.
have good day.
Here we go.
It's quite difficult to explain - a picture tells a few words.
