Guess the photo? blue resistor
Why is this resistor of a different color and size?
Is he special? why is he different?
What's this? for the detail? written 220 ohms
1-resistor of another power
2 thermistor
3-resistor high precision?
blue resistor
It looks as though the schematic has been printed out before the parts designation has been assigned. this has nothing to do with the value, but the manufacture's ID on the BOM, hence c?, R? etc..
Some CAD systems apply this "on the fly" as parts are added. Some need a button push to generate or update it.
Not likely to be very critical in the ccs.
I know ccs or current setting resistor can be critical. It's the resistance that is probably too small to be critical. But i have never proved it by ears. For very small resistance where noise or temperature is not an issue (usually in series with signal: base stoppers or output resistors) I simply use Allen-Bradley for its 'organic' sound when used as FB resistor (due to less inductance may be?) where it is not really suitable in this FB position due to high resistance, high current, critical duty.
I want to tell everyone a big thank you for your help! You are professionals. I am an amateur!
Tell me more advice! - I hope you are not funny !!
Is there a contact at these points? 1-2-3 I do not understand
Color drawing is that right? or mistake
I want to run a layout !!!
instead of transistors (2sk147-2sj72---2sk240-2sj75) I use 2SJ74/2SK170
the rest of the transistors, I will put the same name.
If the layout starts working --- I will buy original transistors in a Japanese auction
PCB-there is a mistake, I will correct
