Hi friends,
I was build this amp: www.jogis-roehrenbude.de/Verstaerker/GU50-Grommes/GU50.htm
It is slightly modified this EL34 amp: www.jogis-roehrenbude.de/Leserbriefe/Roessler-Amp/Bauanleitung.htm
My question: Please, what anode current I can use in this GU50 amp ? 😕 I use about 460V DC in anode and -70 in bias input ..
PS: I use on tubes AC heater with this reference because with AC heater was hum in sound ...
Sorry for my bad english 🙂
I use them with 850V B+, 10K P-P output transformers, and 30 mA idle current, for 100W output power from a pair.
Thanks,
Really? :-D
I tested it on 460V and 30mA and after about 15min are GU tuber very hot. Then, it is normally ...
.. I have 6.6kOhm OT...
Really? :-D
Tubes suppose to be hot. Gu-50 is rated for 40W anode dissipation, but they can sustain shortly more than 100W dissipation. Anodes are made from a nickel alloy, and covered by a stuff that absorbs gases. It is a genuine Telefunken design of military tubes.
If you use UL connection as in the link at the start (g2 at anode voltage) then 460V 30mA is with -Vg1=95V !Thanks,
Really? :-D
If it is -60V what you said before, there is something wrong.
460V with -60V gives 150mA, much to high.
Mona
I never tried Gu-50 tubes with more than 270V on G2. Their control grids are dense and fragile. I would understand 460V triode connected, but in UL?!
Hello Misko, i have here exact the same amp (used the schematics an PCB), it works. Question is - which power supply schematics are You using. There are a few, the last (working) one can be found here:
Without signal triode or UL gives the same current in the tube.I never tried Gu-50 tubes with more than 270V on G2. Their control grids are dense and fragile. I would understand 460V triode connected, but in UL?!
The schematic the TS uses is for the EL34 but they put the GU-50 in.
I don't like the idea, it seems to funtion but noboddy tells for how long 😀
Mona
EL34 has rarer and thicker screen grid, 450V on G2 is withing specs for it in pentode mode. 20V saturation at 150 mA. Gu-50 at that point has about 80 mA G2 current. That'd why in my amps I sense G2 current to control optical input attenuator that decreases gain of the amp flashing red LED.
Thanks you all my friends ! 😉
Nikita63: I dont buy "VB408" than I use and build external source with 2x 285V DC. (almost identical to yours scheme)
https://photos.app.goo.gl/NwtvQfmiMdCmdvFM8
https://photos.app.goo.gl/VpMRBNbSZDbYhcUM8
Look, this is voltages which I was today have on test points:
https://photos.app.goo.gl/VpuHp8RTf5o3pSnB9
At these voltages values are anode currents 32-33 mA ... (33mV on catode 1 Ohm resistors) Is someting wrong on that mr. "Ketje" ? 😕
EDIT: I see, you told about 460V on G2 but I meant anode voltage. On G2 I have only 271V ...
That's a different story, no UL ! I supose you have about -45V on g1 now and a much safer situation for the tubes.
Mona
Mona
That anode current is quite low. Optimum linearity with 6k6 output transformer and 460 V supply voltage is achieved with some 50...60 mA.
I don't use GU-50 without +12V on the 3'Rd grid.
Positive G3 allows higher G2 voltage, for the same G2 current, hence higher anode current swing and lower saturation voltage. I used that in my amps with GU-50, 813 and GK-71 output tubes.
Dear Wavebourn,
we are actually try to see if it's possible to design a big brother of the Baby Huey, and on of the hardest tubes to implement is the GU50, and I think your intervention could bring a very fresh breath to the thread:
Baby Huey enters into puberty: 6550 KT88 possibly GU50?
Thank you in advance.
Roberto
I want to built the same amplifier as misko1985 but I have OPT Raa 3k with CF. Ub will be around 450V I suppose, what is the right current for gu-50 in this case? Maybe I try also triode connection. Thanks.
- Tubes / Valves
- GU-50 PP
