Group buy/Interest list - TDA1541A Core board.
Please vote for your prefered surface finish
  • HASL - Hot air soldered leveling (cheaper option)
    Votes: 6 12.2%
  • ENIG - Electroless nickle/immersion gold (slightly more expensive but higher quality)
    Votes: 43 87.8%
  • Total voters
    49
And We are not totally free the world bankers elite run our gov as well as europe same world order system.
i like when a thread run into many directions...
The bankers could be an Australian predator, something between the Black Mamba and the crocodile… same economy of movements and equal dangerosity for the prey !
But we have far worst predator here : State ! But nearer than the red ants : always hungry and too many... in automatic setup. Here the main role of the citizen is to feed them !
Here in France if the Distinctive was maid with a banker it would cost 100 dollars but maid buy a state employees with their particular competence and with public buying market and state buyers : it will cost you 1 000 dollars (notice than in all case the banker keep him 100 bucks 😀).
Here 2/5 of the workers are state or local aera employees. If all the taxes are add up this is 70% of the money kept between the job and individual taxes. Many are redistributed with some services but all are wasted by lacke of effcienty ! Can you believe it : We are near of 100% debt in relation to the valor creation and near 8 years of annual state budget ! Where is the money ????? State became an octopus at its own service : citizens serv it not the normal opposite. Private work is braked to serve the state employees and we are not able anymore because of that to create real values !
About the caps, sure ask in the the tda kit thread... more easy to talk about it. No ceramics caps for the 14 positions decoupling : PPS or acrylic smds... Again for PS decoupling (3 voltage rails) : try first without decoupling but the good choosed polymers (or Black Gate if you have it : seems to work well with the TDA). Try after PPS caps or acrylic caps for the PS decoupling smd pads 0.1 TO 1 uF: expensive and fragile (take care with temperature and put your body to earth with a good iron solder !). Smd 0603 case X7R should work but are said to be not a good match with ears... not sure with a good polymer and a small value...
Go with the advises of the ancients here and elsewhere on the Web : Thorsten, Pedja, Guido Tent... they know !
I know its probably a bit early yet to ask but ryan what part values would you recommend to get this up and running? Thanks
Hi Peterma,
It really depends on a few things. For the filter caps, if you're running the DEM as low as 60k, then you will need 1uF x 14. But if you have a 470pF on the DEM, then you will only need about 220nF. At the moment i'm running a 470pF cap with 1uF cornell dubilier stacked film in a 1210 package, soldered on sideways.
As for the AOL and AOR caps, it depends on your output stage Zin, With my 12 ohm Zin i should be using about 47nF, but at the moment i haven't anything in the position.
As for the DEM resistors, 6k8 is what i recommend to stabilize the dem oscillation.
Also, please take note of what caps Eldam has experimented with, hes tried a heap of different caps.
Cheers. :drink:
@Shane, my spelling is ok with spell check! 😀
Commmmercial, haha.
A cat with a mouse under its thumb is a happy cat ! Look at this one, it doesn't care and look at the screen playing to "Black Ops" !
:cop: : mod Distinctive team to Ryan: keep serious please !
Total =88
8 left ...
Pffff not receive my pcb yet, France is at the end of the horizon line, my pcb is still swimming to touch it !
Two cents questions if 6K8 resistors used, is there palce to put smd low noise Sussumu RR or a simple 1/4 W Dale is ok pin to pin ?
:cop: : mod Distinctive team to Eldam: keep serious please !
Total =88
8 left ... -1 (back up for french savan !)
Total = 88
7+1 left (=8)
Arrived this morning...i.e. now ! With a nice drawing on the pack up paper !
Wow, this tiny pcb is very impressive in the real life... I'm sudenly shy in front of it !
Thank you very much Ryan, you are the Picasso of PCB drawing and a Japanese origata master !
Total = 88
7+1 left (=8)
Glad you finally received it!
Not bad time though, one week exactly to the other side of the world.
Thought you might like a little smile to light up your day. 🙂
🙂 :up:
:hug: wooookieeeeeeeeeeee !
:cheers:
P.S. : it's easier with pcb in front of me : I will make a BOM of resistors and caps ref to allow easily good size pitch with more than one choices to allow own tests for each diyers. E.G. one of the ref I gave above has too big thick legs but have an as good equivalent in 2 mm pitch with thin legs...
Little smartphones screens are a terrible thing.... try page 21 !
CFT x1
Ceglar x2
Pet-240 x 2
Skippyboy X 2
Eldam x 1
AudioLapDance x 2
badrisuper x 1
Audiohifi x 1
Palmito x 2
peterma x 2
mravinsky x 1
JimS X 2
neoinc x 1
crowlie x 2
SPWONG x 1
Aronier x 2
andrea_mori x 2
ekidnah09 x 1
BDL x 2
RTD x 2
Luke X 2
savvas X 2
Jaffrie X 2
cjunkk x 1
flyboi X 2
wlowes X 1
bkdog x 1
clivem x 2
Malvin x 1
northernsky x 1
RonR x 2
kazap x 2
audiorogert x 2
dookie182 x1
noizas x 6
sandor x 2
vanwykca x 2
walangalam x 1
kp93300x1
cox77 X2
Jogi x 1
GaryB x 2
analog_sa x 1
gnnett x1
bracla x 2
meintan X1
kamaths x1
av-trouvaille x2
JOHNNYCR100 x3
pji x 1
ppap64 x1
JethroTull x2
Myint67x2
greg7 x1
Total =88
8 left
I'd like one as well.
CFT x1
Ceglar x2
Pet-240 x 2
Skippyboy X 2
Eldam x 1
AudioLapDance x 2
badrisuper x 1
Audiohifi x 1
Palmito x 2
peterma x 2
mravinsky x 1
JimS X 2
neoinc x 1
crowlie x 2
SPWONG x 1
Aronier x 2
andrea_mori x 2
ekidnah09 x 1
BDL x 2
RTD x 2
Luke X 2
savvas X 2
Jaffrie X 2
cjunkk x 1
flyboi X 2
wlowes X 1
bkdog x 1
clivem x 2
Malvin x 1
northernsky x 1
RonR x 2
kazap x 2
audiorogert x 2
dookie182 x1
noizas x 6
sandor x 2
vanwykca x 2
walangalam x 1
kp93300x1
cox77 X2
Jogi x 1
GaryB x 2
analog_sa x 1
gnnett x1
bracla x 2
meintan X1
kamaths x1
av-trouvaille x2
JOHNNYCR100 x3
pji x 1
ppap64 x1
JethroTull x2
Myint67x2
greg7 x1
painkiller x1
Total =89
9 left
Hi Peterma,
Cheers. :drink:
Commmmercial, haha.
Hey Ryan, its a little confusing what to use. What are the differences for DEM cap and how should one calcualte what decoupling caps to use?
Same again for AOL and AOR caps. Lets assume I know the input impedance of my I/V, how should I calculate the resistors and caps?
Hi Luke,
I'm really not sure of the calculations off the top of my head, but it really is left up to you to experiment and find what you like best.
470pf on the DEM and 220nf on the filter caps is a good place to start. - A good quality stacked film cap is a good choice.
Have a good read of John Browns thread if you haven't already.
There is an absolute abundance of posts on this forum that talks all about this very topic.
With the cap on the analog outputs, it depends what your sampling rate is at, but you should be safe with about 10nF- but you really need to have a play. Also check out the various online capacitor calculators and have a play.
Ryan
Hi Luke,
Ryan
Luke (I like this surname, I don't know why !)
Try please here the Wima FKP2 for the output : check the pins pitch spacement before ! If two big try 2 mm pins pitch with MKT : Cornell Dublier, Vishay, Wima MKS (in preference order); if you find it radial polystyren also in small case...
There are no total concensus about DEM and TDA decoupling.
Again : you can't mistake with Ryan's wise advice first. John's advise can be tried without fear also and was also given above (different DEM cap value), but read a little about John's thread (last 200 posts e.g.) to understand the philosophy about this choices and your oversampling requirement.
Here again imho for DEM timing cap: COG/NPO smd 0603 near of the pins; SMD silver Mica (bigger case= bigger inductance also); PPS smd; Wima FKP2...
So 7 boards left or 9 ?
Would appreciate 2 boards as well ! Good work.
Will send you a PM.
CFT x1
Ceglar x2
Pet-240 x 2
Skippyboy X 2
Eldam x 1
AudioLapDance x 2
badrisuper x 1
Audiohifi x 1
Palmito x 2
peterma x 2
mravinsky x 1
JimS X 2
neoinc x 1
crowlie x 2
SPWONG x 1
Aronier x 2
andrea_mori x 2
ekidnah09 x 1
BDL x 2
RTD x 2
Luke X 2
savvas X 2
Jaffrie X 2
cjunkk x 1
flyboi X 2
wlowes X 1
bkdog x 1
clivem x 2
Malvin x 1
northernsky x 1
RonR x 2
kazap x 2
audiorogert x 2
dookie182 x1
noizas x 6
sandor x 2
vanwykca x 2
walangalam x 1
kp93300x1
cox77 X2
Jogi x 1
GaryB x 2
analog_sa x 1
gnnett x1
bracla x 2
meintan X1
kamaths x1
av-trouvaille x2
JOHNNYCR100 x3
pji x 1
ppap64 x1
JethroTull x2
Myint67x2
greg7 x1
painkiller x1
Phi x2
Total =91
7 left
