Groner Triple
wheels
Welcome back Edmond.
Thanks.
But for how long? I'm still involved with other things (my bike electronics and increasing the income of my GF, Iron Condors? 😕)
Re-Re invention of the wheel 😉
Pioneer used this topology in more refined version in two or three of their exclusive no global feedback amps back in the 80s.
Oh well........
E.
I believe Dado is referring to the ckt in post 2. I have used bootstrapping like this to supply the drivers in a HEC follower. This way I only need to regulate a few mA for the pre-driver stages. Works great! I plan to use a more refined version in my next proto.🙂
Wow, a circuit named after me 😛! As others have pointed out, there's is no reason for this, as it has been around for quite some time--just not with the attention it deserves, so I put it in my little paper.
Regarding replacing the CCSs with a bootstrapping arrangement: we need to carefully look at what actually limits output swing. If the small-signal stages of the amplifier are powered from a filtered/regulated supply which has lower voltage than the supply for the power transistors, the voltage swing limit will usually stem from the second stage, not the output buffer. In this case there is little reason to not just use CCSs.
Samuel
bias stability
although this might result in somewhat reduced bias stability with unregulated power supplies.
That is what I tried to solve with CSS boostrap in proposed schematic. Did you look at it?
dado
Hi Dado,
Of course you can do it that way and it should work.
But despite a perfect CCS, the OPS bias level still depends on the voltage of the main (and unregulated) power supply. 🙁 To what extent depends on the Early voltage of the output devices. That's why I followed a different route to stabilize the bias level of the phoenix amp.
E.
phoenix bias
By the way, below the bias as function of the supply voltage.
Red: CCS
Green: Compensated bootstrap
Which of the two do you prefer?
E.
You really dislike a bootstrapping arrangement, don't you?
No--at places where it's use is appropriate. In the specific schematic suggested at the beginning of this thread it looks to me (without detailed study) as if the use of the bootstrapping would mostly increase complexity, and gain little.
Because of the electrolytics and/or old school practice?
Electrolytics are the first thing to fail in a well-designed circuit, so any less is an advantage, basically.
Red: CCS
Looks like an unfair comparison to me. Show us the bias stability of the bootstrapping version without any corrective arrangement. Such could be introduced for the CCS version as well.
BTW, do you know how dependable VA is in production (not a rhetoric question, I have no data on this)?
Samuel
Samuel
I called it that way to get some attention on that schematic. If there is not well known participant beyond the tread no one pays attention.
dado
Compared to a CCS, a bootstrap isn't that complex: 2R's and 1 C.
True, but in every amp you will need some electrolitics anyhow. So two more of them has little effect on the overall reliability.
I showed the compensated bootstrap as an answer on Dado's remark:
"although this might result in somewhat reduced bias stability with unregulated power supplies."
Of course you also can apply some form of compensation on a CCS.
Samuel
I don't have exact data. I guess VA will vary as much as beta will. For a given process, VA * beta seems to be constant.
Anyhow, no matter which method is used (a CCS or a bootstrap), in both cases the Early effect will affect the bias stability (that is, with an unregulated PSU).
E.
Have you simulated with 4 and 2 ohm loads - if you plan to go that low?
I am not sure what you want to simulate.
Distortion on 2ohm is still very low.
1kHz 0.000045%
20kHz 0.001604%
Attached is LTspice zip file with sinus and square simulation, and you can try to test what is of your interest and show the result and comments.
dado
Hi dado,
Maybe it's of no concern, but did you have a look at the effect of temperature of the CCS FETs on the OPS bias?
E.
Problem with my simulation is use of standard NJFET from LTspice library. I tried to use Supertex model(DN3135 or DN2540) but LTspice does not recognize it.
With a wrong model I don't see usefulness of temperature simulation. Do you know how to find Supetex spice models that LTspice can use?
dado
As for the DN3135, the maximum temp. coef. of Vgs is 4.5mV/K.
So it's quite easy to simulate temperature effects. Just insert a (small) voltage source in front of the gate.
dado
Sorry, I don't know (I'm using another simulator)
E.
