Golden ratio bass horn
GM, if you can point out what dimensions you need i will measure that. Horn is 2 small straight sections and 3 circlular sections.
dave
Can your program tell if it's expo, etc.? Regardless, every 3" like shown is plenty good enough and for this horn, maybe every 4" in the last, larger expansion. Once these are known it can be broken down into flat panels to 'trip up' its excessive HF.
GM
frugal-phile™
Joined 2001
I can only generate dimensions. 3” apart (at at least 1 end anyway) except where shown. The horn is primamrily formed by 3 circular sections shown in blue, red, purple.
attachment.php
dave
with the offset driver - hornresp could use another section to put the driver where it belongs - can't quite fudge it with the last part having length but essentially no expansion. Is there a good fudge with hornresp?
this may be off in expansion - have to look closer at P10's CAD sketch
has anyone simmed this yet?
frugal-phile™
Joined 2001
The plugs make a positive difference IMO. And hundreds of diyers have installed the plugs in their FE20x and i have only gotten positive comments back. Many were “i don’t know why these don’t come factory installed".
I can only guess on that — cost and momentum perhaps — i have not seen any Fostex drivers with phase plugs. Drivers with whizzers seem to universally benefit from phase plugs. But the driver thou that seems to benefit most is the Visaton B200.
dave
frugal-phile™
Joined 2001
I have my theories. From my web-page:
The phase plugs work primarily 2 fronts. 1st they fill the hole left when the dust cap removed. The air trapped in the cylinder inside the voice coil and above the pole piece causes what is called an "oil-can resonance". This invariably causes some midrange distress. Removal of the dustcap and filling the hole pretty much eliminates this source of coloration. The 2nd thing the phase plug does is to effectively halve the diameter of the cone. Any side-to-side standing waves, reflections, etc are pushed up about an octave. Related to this is an improvement in high frequency dispersion, widening the sweet-spot, and reducing the laser-like hot spot some full-range drivers suffer from. The smaller effective cone diameter means that the point at which beaming starts is pushed up and due to the shaped nature & the hardness of the plugs some HF energy is redirected.
Visaton BG20
Same specification of voice coil as B200 so B200 plugs likely will fit, but you need to remove dustcaps and measure. The FE16x plug is slightly less diameter (and shorter). If the available plug is a bit too large they can be sanded down (which i had to do to use FE10x plugs in the Coral holey basket version of the FE103A).
dave
1st detail translates to the 2nd with length in mm/in and area in cm2
dave
what exactly does the above drawing and measurement tell you?
i have been listening to these for the past year in my studio and I have really grown to love the sound. I cant quite explain what it is about the sound that is different but it sounds more alive and real especially with acoustic, vocal, jazz etc. i have a tube amp im looking forward to trying it with, a fisher x-202. im considering bringing them home to the livingroom
